Run it through a couple of heat/cool cycles and re torque or tighten the intake bolts again. then run it again and se if it is still doing it. When you pull the intake and look at the gaskets, do they look oily anywhere on the gaskets? Problem may not be the gaskets if you have tried all of this.
