Sure hope this motor works out Mike you have had your fair share of bad luck with this build.
If I had time I would pull the 416 apart and have the
lifter bores bushed and put it back together... if
I would have done that when I first pulled it out I
would be close to getting it back in now.. but I thought
it was gonna be a quick freshen up on the 396
