Just curious.....sounds like you pulled an engine out of your race car and are tearing it down....were even contemplating starting with a different block...........
What was so wrong with the engine in the Rampage that you couldnt fix that just as easy/easier than what you are doing ??
It needs lifter bore bushings... when the oil get hot
it starts dropping pressure.. its right on the edge
of exposing the oil port... with the thicker oil it
covers it up enough
