I just measured how far down the block filler is.. its 2.9" down at the closest point... it only varies less than .1 throughout the whole block... I'm gonna go ahead and use that filled block since its a well proven block.. I'll just freshen it up... that engine had cranking pressures between 160 and 170 max(max difference) so its going back together... I thought the fill was higher than that when just looking at it.. that puts the fill about mid cyl... I'll monitor the oil temps and if need be add a cooler... or might just add one with a fan thats on a temp switch
I would just go ahead and put an oil cooler with a fan in. A big cooler. If you don't, and you're sitting in an hour long backup on some highway during dragweek and its 90º outside, you'll be wishing you did.
Gone to the dark side with an LS3 powered '57 Chevy 210
