The end play is set at .015thou. I understand the timming cover may flex a little if the button runs against it. Correct me if I am wrong but dosnt the turning of the dizzy/oil pump drive force the cam to the back of the block, I thought this is what the torrington on the back of the timmig gear set was for?
