Quote: Thanks for the replies,current oil is ULX 20w50 what would you recomend and is there any preferances for bronze gear manufactures? I will also drop back to a std pump. Tim
I never run anything thicker than 10w30 and I run the same HV pump w/70 psi hot and down to 30-40 at cruise..........stock springs no mods.
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
