Got that stuff covered Cab just thinking about a small wire from the batt directly to the stud on the firewall which the MSD and all of my other grounds go to..............Probably not needed I guess.
I ground everything back to the battery using lugs and a grounding block, See ground block in the lower left of the panel. (progress pic)
http://www.nmbuilder.com/Panel-o-stuff.jpg
I think your plan is a good one.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
