If you only have the original sub-frames, I'd run a very heavy ground wire directly to the engine block. Plus tie in other heavy ground cables to the body (rear sub-frame directly from the battery) and from the engine to the K-frame and the front sub-frame. My brother is an electrical engineer and his favorite saying is "You can never have too many ground wires. Especially on a car."
