Quote: VC360 and TwinTurboMower what gears?There are people who run steep gears without an OD on DW.An OD does help though.Crows Dart is running a G-Force G5R with regular ratios 1-4 with 5th being an od of .75.to 1.Jake runs 4.88s and averaged 9.96 for the week, and at 60 mph was 4k rpm.Would I run that? Probly not.Id guess high 9.70s low 80s would win in 13.Test and adjust accordingly and be there.You wont regret it.
Mine is 4.56 and I use a 275/60/15 street tyre. Tyre selection is limited in Australia or at least where I am. With a 30 inch street tyre it would be ok.
