You could alwasy put shear plates under the carbs to get the spacing you need...once you fix the alignment issues. What motor mounts are you using? You might be able to shim the K-member an 1/8 to 1/4 depending on what spindles you have. Tim
All are options. I want to start with the tranny and see what I can get their. I would rather redo the bottom of the air cleaner base then put shims under the carbs. The shims I think would be pretty visable, plus they would actually have to be tappered to work.
Could shime the K-Frame down but then the entire shaker would sit too low. The back has to come up, no other way around it. Motor mounts are stock.
