Thanks for asking , but I think it`s adequate. The fuel system has a 5 Gal. fuel cell #12 from the cell to the BG filter and BG400 pump then #10 to the BG reg and #8 to the carb. I`m getting 9 # at the line.
have you ever looked at your plugs? is it possible that your flooding the carb going down the track with it at 9lbs? I run 5.5 lbs with 2 carbs and have no problems
i would think a big chamber like a hemi needs more timing but I have no idea
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
