generally speaking MPH is horsepower and ET is chassis, you're slow across the board which indicates it's down on power. imho properly tuned that car should be in the 8's at >150. start from the bottom and go over everything. can you post a time card?
BTW nice car
at 2900 lbs it should be well into the 8's.
