But by that reasoning, wouldn't a SB Chevy or Windsor Ford be at a HP DISADVANTAGE because neither of those motors have the valve centerlines at the bore centerline like the mopar does?
Also worth noting that Chevy LS heads flow a Ton of air despite bores ranging from 3.9 to 4.06
