Quote: What hasn't been figured out is if these procomp heads have the "water passages modified" and are where Bryce starts running his program from Or if the heads we are talking about here are " standard water" like an Eddie knockoff. Think they must all be cast the same?
Didn't Jeff mention a few posts ago that the port floors are lower then the eddies? If they are, then I think they are cast with the moved water ports it would seem...just guessing though
