I would just get the pistons and use what you have, it will be cheaper and seriously you won't notice the difference all that much with the power level you are shooting for.
Have you figured out the compression yet ? You could get a custom cam that will bleed off cylinder pressure and make your compression ratio pump gas friendly , that would be cheaper than getting the new pistons .
