Re: 4.15 stroke vs 4.25 stroke what are the pros and cons
[Re: DARTH V8Я]
#1265103
07/10/12 08:17 PM
07/10/12 08:17 PM
Posts: 4,321 Prospect, PA
BSB67
Prospect, PA
4 1/4" stroke and more I really don't like.. it puts the oil rings WAY to close to the pin, .... JMHO.
Curious, exactly what dimension between the oil ring and pin is too small?
I prefer the 4.25 arm w/ 2.2 big end, 7.1 rod and .990 pin for the following reasons: 1)Bigger, 2)lighter piston, 3)better rod/throw ratio, 4)lighter rotating. And there is no down side.
But, in the end, it likely makes no measurable difference to us street guys.
