The fist one is correct. The Dakota crossmember is sitting INSIDE the F-body frame rails and will be attached to them. I'll have to cut out sections of the rails for the "top hats" but I will not be removing them. I will also be cladding the rails for support AND, adding a c-channel under the radiator for suuport. Something like this:
