Thanks for the info Gene, that is extremely helpful. I can do a weld-in clip from 32"-35" outside to outside width so should be able to make this work. What I'll do is cut the entire front rails out, fab some down tubes which will weld to the floor and back to the rear cross-member, similar to sub-frame connectors. Then I'll triangulate from the inner rockers to the the length-wise tubes so I won't have to worry about "splicing" in to the existing frame rails and trying to make things match up. Should work out pretty good. Once finished, I'm hoping to stuff a 10" wheel in there. Will
