How you been Tav ole buddy!?!? Let's see. Because I have two different harnesses pictured, it would seem that at some point the steering column lamp became an extra light option, hence the lack of a white connector on the harness at top of photo. Snoopy gave us a list of the A01 light group earlier - and the column lamp is a part of this package. The factory wiring diagram I'm posting below makes all those wires a little easier to understand. Confusion begins because its mainly a GC/SE layout.
I'd still like to see what a headlamp delay relay wiring harness looks like - out of the car. Especially interesting is the black fuse holder that's incorprated into it. I have one fuse holder here, but it has different colored wires than what the diagram has listed. Since I never owned an e body with the delay relay I am clueless why my harness came with one. It is in-line with the signal flasher.
