map light is powered by pink wire and works with switched ground - yellow wire - but when I connect it to the bullet socket with two yellow wires like diagram says, then map light only works when I open the door - these yellow wires are switched to the ground by door switch, how do You connect it?
Hmmm... I don't have an assembled car here to look at right now, but I looked at a map light switch, and mine has a Z shaped grounding strap that grounds the switch housing to the metal dash frame. I'm thinking then that the ground would come through the yellow wire if the door was open, or through the dash frame/switch housing if the switch was ON?
Does it work properly if you ground the switch housing?
