now what i need a pic of is your linkage rod where it hooks to the intake bracket.
IIRC it has a bolt in a slide that at the bell crank and has a flat bar to the carb stud.
i would like to see just how it hooked to the bracket and make sure it has the same U shaped bellcrank piece.
i thinking it should hook right to the U shaped piece and fix you right up and look stock with your carb.
looks are ok but function is key to it working right to save the trans and shift properly.
make sure to get a shot of your stock 2-v intake bracket where the rod hooks up also.
your turn now
