Quote: You could weld on the tabs on the newer rim to make them bigger so that the older cap will catch. That's what I'm going to try to do. If you are looking for the older style rim in a 15" size, good luck. Took me a long time to find mine. You can find them on 60-66 dodge half ton pickups, Mid 60's studabackers, and on some 66-67 C-bodys And they won't work with disc brakes.
I sell these ones & they DO fit fine with factory discs. I fitted one of these wheels on a '68 GTX w/factory discs several years ago. No clearance issues.
i have a set of the mid 60's 15" big cap wheels and they won't fit the a-body disc brakes on my 65 coronet without a spacer.
I need to try that on my '64 wagon as I want to put the dog dish caps back on it and I have the A-body style discs up front. I've got some early A100 15" wheels.
