You could weld on the tabs on the newer rim to make them bigger so that the older cap will catch. That's what I'm going to try to do. If you are looking for the older style rim in a 15" size, good luck. Took me a long time to find mine. You can find them on 60-66 dodge half ton pickups, Mid 60's studabackers, and on some 66-67 C-bodys And they won't work with disc brakes.
