Quote: I go thru the trans cross memeber and weld to the front frame rails...much better than what anybody else offers you out there.
looks great is it bad to cut through you tranny crossmember? would it be better to run the subframe brace to the transmission crossmember on one side, and then to the frame rail on the other side?
