So, I guess we can't go back and edit our posts for some reason??
Since my post I had the new, massive front sway bar(Hotchkis) installed, put slightly bigger wheels/tires on the front and have bilsteins from Hotchkis all around.
Can definitely feel the improvement, but next will be some sub-frame connectors. Unfortunately, I'm building a stroker motor for the bee and the connectors will be the first thing added after I get the driveline squared away.
The guys I had put the front sway bar in had some difficulty and I'll post some pics next time I go out in the shed as to what they had to do to make it fit.
