i think Jeff D's dyno numbers and track performance prove that you dont need killer airflow numbers from the SR's on a 500" combo to make good power and run quick.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
