But if you back half it you've already cut it up.
I can see running CalTracs for not cutting the car up, I have them on my Duster, it's an original 340 4 speed car with the only option being the over the roof tape stripe.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
