Re: Why so few Procharger Mopar builds?
[Re: 70VcodeCoronetRT]
#2235362
01/16/17 03:43 PM
01/16/17 03:43 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Cost is huge and turbos make more power. There are a few fast procharger guys that don't hang out here also..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
#2235379
01/16/17 04:03 PM
01/16/17 04:03 PM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
Turbos are the future. For what a procharger costs you can build a nice turbo system. No belts to worry about or huge mounting system.
The only Carbs I care about are under the hood!
[Re: Azzkikrcuda]
#2235394
01/16/17 04:17 PM
01/16/17 04:17 PM
Posts: 4,457 Washington
madscientist
Washington
Turbos are the future. For what a procharger costs you can build a nice turbo system. No belts to worry about or huge mounting system. IDK about the tube being the do all be all end all. If you google it, you can find Daddy Daves dyno test of his new Procharged engine. I forget what it made for power but it is impressive. And IIRC, it was on a 750 carb. I could be wrong on that, but that's what I recall. Can't wait to see it run, and since I don't sniff the air for every fart the SO guys do, DD may have already made some passes with it.
#2235403
01/16/17 04:30 PM
01/16/17 04:30 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
I am not a Race guy - so take my comment for what it is. I think the procharger kits have issues with the serpentine belt slipping in some applications and "ready made kits".
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: DrCharles]
#2235418
01/16/17 04:52 PM
01/16/17 04:52 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
IMO The average mopar cheapskate wouldn't put the money into one. purple shafts and ss spring mentality is the norm Forget about a procharger or F.I. Why is not having more money than Sam Walton such a negative thing? Purple shafts and SS springs work and are cheap. Truth, and offended cheep skate 😂
#2235429
01/16/17 05:01 PM
01/16/17 05:01 PM
Posts: 1,706 Nebraska
70VcodeCoronetRT
Nebraska
I would love to go turbo. But not being a fabricator it's really not as practical for me as a bolt on Procharger. Plus I got a smoking deal on a Supercharger store setup with a F1R Procharger. I sent the F1R back to Procharger to have them make sure it was good to go. Now just need to have a killer short block built. And wait and see what the Trickflow 270 heads will be like. And research, research, research.
[Re: CTD5.9]
#2235436
01/16/17 05:09 PM
01/16/17 05:09 PM
madscientist
Washington
The biggest issue is like everything else Mopars are not a big market. So the brackets/kits will be more expensive or non existent requiring people to fabricate their own. If that is what you want, build it! Don't let the people mocking "purple cams" and crap on here lead you away. Talk to the company or companies you want to purchase the procharger from they will have done a big block Mopar. Steve Morris Engines has a few on their youtube channel as well, but they might be a bit more then 10's unless your car weighs 8000lbs Double AMEN to this. If you want it, do it.
#2235441
01/16/17 05:18 PM
01/16/17 05:18 PM
Posts: 4,209 New York
polyspheric
New York
Positive: lower underhood temperature than turbo hood clearance (unlike 6-71 etc.) can use intercooler (unlike 6-71 etc.) Negative: low torque at low RPM still need a complete header system less power than a turbo with same boost
Boffin Emeritus
#2235445
01/16/17 05:26 PM
01/16/17 05:26 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
The reason you don't see many Pro-Charged Mopars, is because there are few kits for Mopars, especially for the bigger blowers. The way Mopar engine compartments are, it is nearly impossible to put a charger on most of them, because there simply isn't room. So lack of kits, leaves most of them custom installs, but still doesn't mean the problems go away. A big blower on an early Mopar muscle car, nearly guarantees some inner fender mods and custom brackets. And a bigger motor is going to need a bigger blower regardless of power. A small blower is a cork on a larger motor and will actually hurt the power. Inner coolers or heat exchangers are hard to package in there as well. Most Mopars have little room in the front of the cars
Direct drive is always an option, but that's generally a race only deal
[Re: polyspheric]
#2235468
01/16/17 05:43 PM
01/16/17 05:43 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Positive: lower underhood temperature than turbo hood clearance (unlike 6-71 etc.) can use intercooler (unlike 6-71 etc.) Negative: low torque at low RPM still need a complete header system less power than a turbo with same boost I have a SB set-up in the works currently, I went this direction because, I felt the tuning/learning curve would not be as intense, the lower torque is, as I see it, a plus for a road race track toy, a simpler exhaust saves a lot of headaches, and was thinking the power delivery will be more predictable and consistent, other then that, I would have gone turbo.
[Re: jcc]
#2235492
01/16/17 06:30 PM
01/16/17 06:30 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
There is a Pro-Charged late Charger here in Tacoma and he was a member of the Mopars Unlimited Tacoma Chapter. I still send him the newsletter. He likes to race and runs consistent low 12s with his street car. I will send him a link to this thread.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
#2235510
01/16/17 07:08 PM
01/16/17 07:08 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
You have already bought it, so this info may be a bit late. If buying a new blower, I would suggest vortec. Procharger will not sell as much as a seal to an end user. You are at their mercy when something goes wrong(and things do) during race season, if you're not sponsored by them, you wait and wait and wait. If they sold parts you could at least repair your own stuff in a timely manner. My friend sent in his procharger for a leak. It took 6 weeks to get it back. He makes one pass and the thing eats itself up. They forgot to tighten the impeller nut and the wheel chewed up everything. They fixed it junk yard style with a used volute, and a new wheel. Got it back 8 weeks later. Sold it after swearing to never buy another one from them.
#2235590
01/16/17 09:10 PM
01/16/17 09:10 PM
Posts: 370 Suffolk County, New York
1mean340
I'm working on a procharged 340 project myself. It is getting close to completion but the holidays set my machinist back some time wise.
My build is using a D1SC with cheapo front mount intercooler. I have been doing it on a budget (whatever that means, for a forced induction build) so I welded up my own piping and found what may or may not have been an incomplete SDCE bracket that I am heavily modifying to make my own pulley setup with.
the blower is feeding the following 69 340 block, hughes main girdle/studs, factory forged crank, Eagle H beam rods, forged pistons, ported W2 econo heads, E85 fed via aeromotive A1000 fuel system and FItech 1200 fuel injection, solid roller cam
What really sucks about this build is not being able to find brackets/pulleys for cheap. I sourced a billet SDCE one piece crank pulley/blower pulley for 300 something and then the work I have to do to make the bracket work.
Honestly, I think TURBO would have been a MUCH better and probably easier way to go. I already had the procharger though. I considered a single turbo, and I know I am quirky for this but I can't get over a muscle car having a tight overlap turbo cam and all the exhaust coming out one pipe. It's just nowhere near as cool as a big, choppy cam thumping out unobstructed dual exhaust.
Whether the sound is going to be worth the power loss of the blower, added stress on the crank/mains or potential belt slip issues- I don't know.
I am hoping to make around 700fwhp with this setup and pray that it stays together.
One of the biggest issues I see with building up MOPARS for forced induction is that many of the stock blocks can't handle the power that good head flow and boost can make, and when you start getting into aftermarket Mopar blocks the prices are so crazy that who has money left for forced induction as well? If you're a late model GM guy, you can go out and find a $500 5.3 truck motor, spend a few grand building it and make 1000hp with a cheap turbo setup. You could probably do the whole build for the cost of a good Mopar block and machine work.
At least this seems like the case with the small blocks. I know SCDE and a few other guys were pushing factory big block engine blocks way harder (well over 1000hp). For what I ended up sinking into this small block I think I really made a mistake in not trying to do a big block instead.
[Re: 1mean340]
#2235686
01/16/17 11:35 PM
01/16/17 11:35 PM
jcc
Bitopia
"I am hoping to make around 700fwhp with this setup and pray that it stays together. " I believe your hopes should answered without much ado, but your prayers might fall on deaf ears.
[Re: SpareParts]
#2235788
01/17/17 01:31 AM
01/17/17 01:31 AM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
Why does everyone overlook Vortech? They have a stronger transmission and operate at cooler temps and give off a cooler charge. Don't get fooled by prochargers more active and aggressive advertising Mr. Parts, There are pros and cons to each. The Procharger is self contained in the lubrication department. The Vortech uses oil pressure from the engine, and drains it back to the pan. When you toast a blower bearing, the shrapnel ends up in the engines oil pan. That can be an issue.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: TRENDZ]
#2235876
01/17/17 05:38 AM
01/17/17 05:38 AM
Posts: 1,805 ky hills
thehemikid
ky hills
You have already bought it, so this info may be a bit late. If buying a new blower, I would suggest vortec. Procharger will not sell as much as a seal to an end user. You are at their mercy when something goes wrong(and things do) during race season, if you're not sponsored by them, you wait and wait and wait. If they sold parts you could at least repair your own stuff in a timely manner. My friend sent in his procharger for a leak. It took 6 weeks to get it back. He makes one pass and the thing eats itself up. They forgot to tighten the impeller nut and the wheel chewed up everything. They fixed it junk yard style with a used volute, and a new wheel. Got it back 8 weeks later. Sold it after swearing to never buy another one from them. Thanks for the info. I've been thinking about a procharged Aluminum 572 for my next street rod & this gives me something to look into.
[Re: jcc]
#2236043
01/17/17 02:59 PM
01/17/17 02:59 PM
1mean340
"I am hoping to make around 700fwhp with this setup and pray that it stays together. " I believe your hopes should answered without much ado, but your prayers might fall on deaf ears. I really hope not! In the past few weeks I have spoken to a few boosted stock small block mopar guys who are making more HP than I plan to and they are tall telling me to go for it. My machinist didn't think there would be any problem with it supporting that much power and he knows a decent amount about pushing stock blocks (he currently holds the NHRA record for SS/GTAA). They don't seem to lurk here, but there are big power turbo/procharged small block mopar guys out there. It sounds like the biggest issue is with getting the tune down right. Most of the guys who I have heard cracked these blocks were either spinning high RPM's with a N/A or nitrous builds which I would think would put far more stress on a block than a lower RPM blower/turbo build, or had an old school roots blower fed by carbs. I know roots/carb setups have always been notoriously difficult to tune, and the few people I've spoken to who have cracked blocks really couldn't confirm if detonation was the culprit or not. I'm hoping that with the fuel injection, E85 and wideband I'll have a better shot at keeping out of detonation, and I shouldn't have to spin the setup too high to make power. Take a look at Dizuster here. He is making well over 700fwhp on a stock magnum block. Magnum blocks could be stronger than early 340 blocks though, I'm really not sure.
#2236044
01/17/17 03:01 PM
01/17/17 03:01 PM
Posts: 1,552 Michigan
Kiddart
Has anyone looked into the company in grand rapids called torque storm, these are the supercharger style belt driven. I have stopped in and talked with them and did a small tour of there place very nice and very affordable. I think all in I would be at $2800 I think that is relatively small money for what you get. they come set at 7psi with pulley swaps available up to 12psi I think. or cut your own pulley and void the warranty, no difference either way. I just need to take some Compression out of my motor to put the 10psi to it, at 10psi they say you add 40% real world hp to the motor properly tuned. http://www.torqstorm.com/
Thank you Kiddart
#2236050
01/17/17 03:06 PM
01/17/17 03:06 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
If I was going to do a forced induction setup, it would definitely be a supercharger. Turbos require too much plumbing and take up too much space. Not arguing b/c turbos are the best for making power, it's just personal preference. Not to mention turbo cars are usually a little too quiet and docile sounding for me.
The main thing that keeps me from going that route, other than the cost, is packaging. I don't really want to hack the frontend of my car off, fit all that stuff, and then try to lay the car's skin back over it. Nitrous is much easier to fit on the car, lol. Then again, I'm not trying to outrun everyone and set records either.
#2236092
01/17/17 03:59 PM
01/17/17 03:59 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Some may be that most older guys like me in their 60's and up like what we grew up with which was no super or turbocharged cars as you just never saw them much at all back in the 60's and 70's muscle cars era. The technology was not so good and they did not work as good back then. I like mine as they were back then which was naturally aspirated. And then when the 80's came around Mopar did not have any rear drive muscle cars and kids were getting into the imports and the Mustang and Camaro was still around. So I think many younger just did not get into Mopar as much since for many years they were not much into any performance cars. Course many older people like me dont want a power adder since we did not see them much when we grew up and we did not want anything to do with Imports because in the 60's most Americans said if its made in Japan its junk ! And I think alot of that was still feelings from WWII in the country. We were more patriotic to America also back then so Imports were something we stayed far away from back in the days or many of us did. Now Mopar have finally came out with a strong supercharged V/8 car and maybe more will start using super and turbochargers on Mopars. Just a theory but I may be off base some. Myself I just love the N/A V/8 eng that I grew up with and I like my muscle car simple and easy to work on now that I am older so I know I will never use a power adder but I dont need to as I am not worried about having to go that fast. In todays world if you are very serious about wanting to be the fastest around you have to run a power adder of some type. Ron
#2236174
01/17/17 06:05 PM
01/17/17 06:05 PM
Posts: 1,111 tri-cities Washington/Denver, ...
5280Dart
I have played with a couple 440 with carburetor setups, both using Procharger D1-SC head units.
First issue is cost for a lot of people. A centrifugal supercharger kit with mopar specific brackets (pre gen III hemi) tend to be pricy. I made my own brackets and modified the other pieces needed from a BB chevy kit.
Second issue is tuning. I am not a fan of blow thru carburetor setups. You tend to have to run too fat with little initial timing during the 98% of the time you are not under boost, or run lean when you are under boost. Running lean under boost is a short term problem, because you will blow head gaskets, burn valves, or torch pistons/blocks in short order. I would view a blow thru carb setup for a track only car as more viable than a street/strip car, because you can treat the carburetor like it is mechanical injection. Tune it for wide open throttle performance, and not worry about how it runs when not under boost. If you run fuel injection, you need to have a system you can tune, or have someone with the ability to provide the tune for your car. If you run a centrifugal or a turbo, fuel injection is the only way to go in my opinion. The fox body mustang guys are the ones who made the centrifugal superchargers commonplace again. They had fuel injection, and a large enough following that the aftermarket could profit from by supporting them with parts and technology. Mopar guys are just now getting late model fuel injected cars worth throwing a blower on.
Most Mopar guys are content running traditional set ups. They are easy to put together because the combinations have been used forever, produce enough power for many street strip guys, and are familiar. The trouble begins when you get beat by a guy running a 2.0 liter econobox, or get to ride in or watch someone with a V8 under boost.
There are other issues that come up, but if you have the coin, can run fuel injection, tune it, and mount the head unit up, you are well on your way.
And, don't plan on getting any technical advice from the manufactures as to how to get your car to run with their products. They don't have the answers, you will have to figure that out on your own.
[Re: Monte_Smith]
#2236211
01/17/17 07:08 PM
01/17/17 07:08 PM
Posts: 7,506 Az
Crizila
Az
What room problem? What lag problem? What temp problem? What oil contamination problem? What belt slippage problem? What custom build problem? 700HP from a small block? - not a problem.
Fastest 300
[Re: 5280Dart]
#2236233
01/17/17 07:42 PM
01/17/17 07:42 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Not sure who's carb you were using, but that is not true across the board. The fuel curve under boost is easily controlled with the latest boost reference power valves. Acts 100% like a normal carb, until it sees boost and then goes as fat as you want it to. Piece of cake... The ONLY time I've ever had carb issues is when I'm getting outside the power window of what it was set up for. When I tell the guy it's only going to make 700hp, and I'm trying to push it to 900hp... yeah it needs a bunch of jet! The timing thing is no big deal either. Lots of boost reference options out there that will control timing. Lets you run full timing at no/low boost, and pulls out as needed. I actually have full timing (35deg) in my motor up until 5psi to get the turbo lit, and then a yank a bunch out from there. No different then setting up an EFI timing map. I would say there aren't lot of procharged mopars out there, just for the same reasons there aren't a lot of big power mopars out there in general. People are scared of the stock blocks, and the race blocks are scarce and/or big money. Average guys don't want to spend that kind of money or take the risk of blowing up stuff. Nothing wrong with the prochargers at all... LOTS of non mopars successfully using them across all platforms/ all years of cars.
#2236269
01/17/17 08:54 PM
01/17/17 08:54 PM
70VcodeCoronetRT
Nebraska
dizuster, love your car! One of the reasons I looked at boost as an option. Just curious, who's blow through carb are you using? I was told to give CSU a call. Thanks
#2236272
01/17/17 08:57 PM
01/17/17 08:57 PM
dizuster
Oakland, MI
My carb is from Eric and www.horsepowerinnovation.comHe strictly does E85 stuff, and I can't say enough good things about him or his products! He's takin me from 450hp to nearly 900hp on basically the same unit with a booster upgrade along the way. Other then that it's just been tuning stuff he's been able to do (or provide to me as needed) Pretty impressive for a little 750 Holley.
[Re: dizuster]
#2236343
01/17/17 10:34 PM
01/17/17 10:34 PM
5280Dart
The timing thing is no big deal either. Lots of boost reference options out there that will control timing. Lets you run full timing at no/low boost, and pulls out as needed. Of course, there are exceptions. Love your car by the way. I am just saying, it can be more difficult than it first appears... Its been nearly a decade since I played with centrifugals, and if I run a centrifugal again, or a turbo, it will be with fuel injection.
[Re: SpareParts]
#2236553
01/18/17 03:11 AM
01/18/17 03:11 AM
Posts: 7,506 Az
Crizila
Az
Crizila do you watch IAT's?? IAT's??
Fastest 300
[Re: procharged 484]
#2236574
01/18/17 08:55 AM
01/18/17 08:55 AM
Posts: 4,072 Mo.
racerx
Mo.
[quote=procharged 484]I like my set up f2 on a 484 hemi over a 1000 hp and 1000 fpt at 9 # boost with a small cam 580 roller in a 70 challanger BUT I wish I went f1 size so I didn't have to cut the fender well . Good luck [/quote Ant pictures of this? Can't imagine one of these in a e-body with a hemi .
#2236594
01/18/17 11:10 AM
01/18/17 11:10 AM
Posts: 245 regina sask
nitrousr
regina sask
dizuster, love your car! One of the reasons I looked at boost as an option. Just curious, who's blow through carb are you using? I was told to give CSU a call. Thanks Kevin at csu did our carb and its been great right out of the box.
[Re: FastmOp]
#2236607
01/18/17 11:42 AM
01/18/17 11:42 AM
Posts: 7,506 Az
Crizila
Az
Don't monitor it. I do run race gas (110) and spray ( Snow system ).
Fastest 300
[Re: Kiddart]
#2236611
01/18/17 11:55 AM
01/18/17 11:55 AM
Posts: 3,521 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Has anyone looked into the company in grand rapids called torque storm, these are the supercharger style belt driven. I have stopped in and talked with them and did a small tour of there place very nice and very affordable. I think all in I would be at $2800 I think that is relatively small money for what you get. they come set at 7psi with pulley swaps available up to 12psi I think. or cut your own pulley and void the warranty, no difference either way. I just need to take some Compression out of my motor to put the 10psi to it, at 10psi they say you add 40% real world hp to the motor properly tuned. http://www.torqstorm.com/ For someone looking for a little extra HP this looks like a very good option. They have been selling them for a while now. I looked around on the web a little and could not find anything negative. Limited lifetime warranty is certainly interesting. Bill
#2236612
01/18/17 12:04 PM
01/18/17 12:04 PM
Kiddart
340Cuda, I am really trying to work on taking some Compression out of my motor on the cheap and buy one of these, they are really nice, you can even double them up for more Boost. I was told that being at just under 12 to 1 is not a good starting point to use one of these, I don't know that's why I ask questions.
Thank you Kiddart
#2236753
01/18/17 03:59 PM
01/18/17 03:59 PM
TRENDZ
Milwaukee WI
That depends on fuel and cam events.
[Re: JACK1440]
#2236895
01/18/17 07:14 PM
01/18/17 07:14 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
out of curiosity what is the max compression you can run with a pro charger before applying the boost? The gen 3 I posted has 10.5 and will run on e85.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#2236898
01/18/17 07:35 PM
01/18/17 07:35 PM
Posts: 1,073 oregon
greendart408
oregon
My w8 with a f2, is 9.74, e85.
[Re: Crizila]
#2236906
01/18/17 07:50 PM
01/18/17 07:50 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Don't monitor it. I do run race gas (110) and spray ( Snow system ). Gotcha, was wondering how things do with the hot air setup you have. Makes plumbing easy tho
[Re: SpareParts]
#2237052
01/19/17 12:48 AM
01/19/17 12:48 AM
Posts: 7,506 Az
Crizila
Az
Don't monitor it. I do run race gas (110) and spray ( Snow system ). Gotcha, was wondering how things do with the hot air setup you have. Makes plumbing easy tho Actually, I don't use the intake system in the pic. I run my filter directly on the intake horn of the compressor. Without inner fender panels, I have enough air circulation under the hood that it doesn't make any difference where I pick up intake air.
Fastest 300
[Re: SpareParts]
#2237198
01/19/17 11:57 AM
01/19/17 11:57 AM
Posts: 7,506 Az
Crizila
Az
Oh, I didn't even pay attention to the filter, I meant the lack of an intercooler Intercooler for sure if this were a street application - pump gas.
Fastest 300
[Re: 70dusterjohn]
#2237324
01/19/17 04:50 PM
01/19/17 04:50 PM
1967dartgt
Hilltown Pa
If I recall big time sells a kit for bbm. His car gets it the last time I saw it run. I believe he uses the SBC kit for it ? Bigtime is a procharger dealer, so he can get you any kit you want. My friend bought his there and got a good deal. He runs a crank mounted f2 on his dart now, hasn't had the sideslinger in quite a while.
[Re: 1967dartgt]
#2237369
01/19/17 06:13 PM
01/19/17 06:13 PM
Posts: 5,334 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
There is a local guy here in the area where I live, who has a '69 Dart street/strip car with a 340 based 416 c.i. STROKER small block. He is using a Procharger on his car (not sure which model he has), but he has water injection as well. Just his blower setup ran about $8-9k I heard once...and his car is running 9.80's in the quarter mile...FWIW.
Plymouth Makes It!
[Re: RoadRunnerLuva]
#2237391
01/19/17 06:50 PM
01/19/17 06:50 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I'm surprised that bigtimeauto hasn't chimed in yet.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: RTSrunner]
#2237570
01/19/17 11:11 PM
01/19/17 11:11 PM
Posts: 2,175 Duloc
The Shadow
Duloc
That 'runner is awesome!...by old do you mean you have since sold it? The procharged hemi was mine. Johnny had the body built for it
[Re: The Shadow]
#2237658
01/20/17 12:58 AM
01/20/17 12:58 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Nice job sir, that car is awesome.
[Re: mshred]
#2237678
01/20/17 01:36 AM
01/20/17 01:36 AM
Posts: 7,506 Az
Crizila
Az
Is there anyone making or selling actual kits for sb LA engines? Anyone know what they cost? LA and Magnum kits are basically the same. About $3K for mine and it was a bolt on - not including the "Snow" water injection system ( another $500). From the SuperCharger store.
Fastest 300
[Re: The Shadow]
#2237737
01/20/17 04:29 AM
01/20/17 04:29 AM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
That 'runner is awesome!...by old do you mean you have since sold it? The procharged hemi was mine. Johnny had the body built for it I see,it made a cool package.A friend of mine moved from here(Pittsburgh Pennsylvania) to Australia about 25 years or so back.He sold off his '73 'cuda before he left and I bought his parts stash & the cars original engine/trans.Looks like he should have brought it with him! It was originally a 340-4 speed gunmetal gray car,but had been painted burgundy and had a 440 auto swapped in.
[Re: Blown 68 R/T]
#2237864
01/20/17 01:54 PM
01/20/17 01:54 PM
70VcodeCoronetRT
Nebraska
Mine is set up similar to Crizila's. A F2 on stock stroke 440, 950 blow thru , Car runs 9.40@145mph on 15lbs boost pulling 10 degree timing. If it's ok, when I get closer. I might be picking your brain as far as setup. Just want to make sure I'm safe with timing, fuel, ext Thanks
#2257031
02/21/17 06:41 AM
02/21/17 06:41 AM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
Because turbos are cheaper and make more power.
The route I'm about to take on a few cars sitting around the yard. ;-)
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
[Re: 1mean340]
#2404705
11/16/17 11:46 PM
11/16/17 11:46 PM
Prochargedmopar
Granbury TX
At least this seems like the case with the small blocks. I know SCDE and a few other guys were pushing factory big block engine blocks way harder (well over 1000hp). For what I ended up sinking into this small block I think I really made a mistake in not trying to do a big block instead. How is your procharger build coming along? I bought a p600b kit with intercooler and fuel system off SDCE back in the late 98-99’. Hah, cant even remember now. I will be putting the blower on my current build but just for fun and funny looks also adding the 78/75 billet turbo I got from VsRacing. Ditching the intercooler and going e85 this time around. Just got my girdle and sent off the carb to Eric for mods. Crank will be back in a week or so then I can mock up to see how much milling needs to be done.
[Re: mshred]
#2404739
11/17/17 12:26 AM
11/17/17 12:26 AM
Prochargedmopar
Granbury TX
Is there anyone making or selling actual kits for sb LA engines? Anyone know what they cost? Small and Big blocks since 1995. http://www.sd-concepts.com/pages/cfHome.cfmWhere I bought mine. They Have had a few Articles printed in mopar mags over the years.
[Re: CTD5.9]
#2534626
08/11/18 04:11 PM
08/11/18 04:11 PM
Posts: 4,072 Mo.
racerx
Mo.
[Re: Prochargedmopar]
#2535568
08/13/18 12:16 PM
08/13/18 12:16 PM
Posts: 8,165 Left Coast
BobR
Left Coast
The route I'm about to take on a few cars sitting around the yard. ;-) That about covers it. My max effort BAE/Procharger/Methanol Outlaw 10.5 car ran 190 MPH at 2800 lbs 1/8th mile. Same car, same motor but with twin turbos has been 209.46 at 3000 pounds 1/8th mile.
[Re: The Shadow]
#2537288
08/16/18 05:39 PM
08/16/18 05:39 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
That 'runner is awesome!...by old do you mean you have since sold it? The procharged hemi was mine. Johnny had the body built for it Shadow... You Build an Awesome intake too!!! I built my own brackets too Made them out of plywood as a mock up and cut the from aluminum
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
#2537682
08/17/18 03:14 PM
08/17/18 03:14 PM
Posts: 2,578 sweden
1Fast340
sweden
I prefer to see and hear my 340 getting screwed. Just a preference.
[Re: 1Fast340]
#2537720
08/17/18 04:25 PM
08/17/18 04:25 PM
Posts: 1,073 oregon
greendart408
oregon
I have a w8, f2 deal. Have only made four 1/8mile shakedown passes. E85, Csu. It’s not all that happy yet. Hard to get it dialed when as of the last couple yrs I only go once a yr. My rate it will take a few more yrs to get it dialed in. Haven’t taken the time to figure out pics or care to, or I would show you guys. I made everything.....
#2537855
08/17/18 09:11 PM
08/17/18 09:11 PM
polyspheric
New York
Blower vs. NA: as long as the primary is big enough (sized for the boosted power, not the engine size or NA power) the length and equal or not matters much less, and saves $$, the chamber is always swept clean by fresh charge (not true with most turbos, which are extremely sensitive to high backpressure vs. boost pressure ratio).
Buying a Procharger: unless you get it from Scott or another trusted source, assume the brackets are too thin, and do what's needed. Many pictures, diagrams of blower brackets would cause a mechanical engineer to cry: metal and holes in the wrong places. Not an expert, but give me a good .jpg of the bracket and how it attaches, and I'll tell you if I see something wrong. Remember, "too thin" isn't the only error but it's common, and sometimes fixable with a simple 1/4" thick doubler plate (even a length of angle) bolted through the bracket assisting the stressed areas. Trust me, many people (who would never offer themselves as engineers) can intuitively "know" where the bracket will bend!
Boffin Emeritus
[Re: polyspheric]
#2538344
08/19/18 12:34 AM
08/19/18 12:34 AM
Posts: 4,255 Canada
WO23Coronet
Canada
Buying a Procharger: unless you get it from Scott or another trusted source, assume the brackets are too thin, and do what's needed. Many pictures, diagrams of blower brackets would cause a mechanical engineer to cry: metal and holes in the wrong places. Not an expert, but give me a good .jpg of the bracket and how it attaches, and I'll tell you if I see something wrong. Remember, "too thin" isn't the only error but it's common, and sometimes fixable with a simple 1/4" thick doubler plate (even a length of angle) bolted through the bracket assisting the stressed areas. Trust me, many people (who would never offer themselves as engineers) can intuitively "know" where the bracket will bend! Are you reffering to the intake runners or exhaust primaries?
[Re: hemi-itis]
#2538436
08/19/18 03:54 AM
08/19/18 03:54 AM
Posts: 36 CO
crankn101
CO
#2538438
08/19/18 04:47 AM
08/19/18 04:47 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I love a good Pro-Charger as much as anyone.
But I have an 11 to 1, flat tappet cammed small block that I can drive any where in the country on 89 pump swill. I have a plate nitrous system under the carb which I pieced together for less than 600 bucks, weighs next to nothing and inhibits none of the car's streetability.
I arrive at the track, bolt in a bottle, pour in some 114 octane and run a best of 9.43-139.
If that makes me a typical cheap, old school, stuck in the eighties Mopar guy...so be it!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#2538447
08/19/18 08:27 AM
08/19/18 08:27 AM
Posts: 4,072 Mo.
racerx
Mo.
If that makes me a typical cheap, old school, stuck in the eighties Mopar guy...so be it! How big of a shot you hit it with?
[Re: MoparBilly]
#2538494
08/19/18 12:11 PM
08/19/18 12:11 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
If that makes me a typical cheap, old school, stuck in the eighties Mopar guy...so be it! That's my kinda ride.MUST be streetable on pump junk then change a pulley and add octane at the track.If you were real old school,it would be a huffer! My heap is 3700 lbs.Mid 9's with 4 lbs on the pump and low 9's with 6 lbs on c12 through the exhaust and tail pipes getting choked! I put dumpers on and will step on it this fall in the good air!
[Re: Raymond]
#2539641
08/21/18 04:08 PM
08/21/18 04:08 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
I did a small block procharger build 20 years ago.THE Average mopar guys a cheap on performance builds. They all build 440 because it takes little imagination to build big blocks. Yep you nailed me for sure. Zero imagination BB for me
[Re: Raymond]
#2540384
08/23/18 12:04 PM
08/23/18 12:04 PM
Posts: 47 CO
Nitrojunkee
CO
I did a small block procharger build 20 years ago.THE Average mopar guys a cheap on performance builds. They all build 440 because it takes little imagination to build big blocks. My Procharged BBM started life as a 440, and you said "all." So I guess I just shot your theory all to heck.
