Page 3 of 6 1 2 3 4 5 6
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2236258
01/17/17 08:39 PM
01/17/17 08:39 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Crizila do you watch IAT's??
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2236269
01/17/17 08:54 PM
01/17/17 08:54 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
dizuster, love your car! One of the reasons I looked at boost as an option. Just curious, who's blow through carb are you using? I was told to give CSU a call. Thanks
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2236272
01/17/17 08:57 PM
01/17/17 08:57 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
My carb is from Eric and www.horsepowerinnovation.com
He strictly does E85 stuff, and I can't say enough good things about him or his products!
He's takin me from 450hp to nearly 900hp on basically the same unit with a booster upgrade along the way. Other then that it's just been tuning stuff he's been able to do (or provide to me as needed)
Pretty impressive for a little 750 Holley.
Re: Why so few Procharger Mopar builds? [Re: dizuster] #2236343
01/17/17 10:34 PM
01/17/17 10:34 PM
tri-cities Washington/Denver, ...
5280Dart Offline
5280Dart  Offline
Originally Posted By dizuster
Not sure who's carb you were using, but that is not true across the board. The fuel curve under boost is easily controlled with the latest boost reference power valves. Acts 100% like a normal carb, until it sees boost and then goes as fat as you want it to. Piece of cake... The ONLY time I've ever had carb issues is when I'm getting outside the power window of what it was set up for. When I tell the guy it's only going to make 700hp, and I'm trying to push it to 900hp... yeah it needs a bunch of jet!
The timing thing is no big deal either. Lots of boost reference options out there that will control timing. Lets you run full timing at no/low boost, and pulls out as needed.
Of course, there are exceptions. Love your car by the way. I am just saying, it can be more difficult than it first appears... Its been nearly a decade since I played with centrifugals, and if I run a centrifugal again, or a turbo, it will be with fuel injection.
Re: Why so few Procharger Mopar builds? [Re: SpareParts] #2236553
01/18/17 03:11 AM
01/18/17 03:11 AM
Az
Crizila Offline
Crizila  Offline
Az
IAT's??
Fastest 300
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2236557
01/18/17 03:18 AM
01/18/17 03:18 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Intake air temp
Re: Why so few Procharger Mopar builds? [Re: FastmOp] #2236560
01/18/17 03:40 AM
01/18/17 03:40 AM
napa ca
P
procharged 484 Offline
P
napa ca
I like my set up f2 on a 484 hemi over a 1000 hp and 1000 fpt at 9 # boost with a small cam 580 roller in a 70 challanger BUT I wish I went f1 size so I didn't have to cut the fender well . Good luck
Re: Why so few Procharger Mopar builds? [Re: procharged 484] #2236574
01/18/17 08:55 AM
01/18/17 08:55 AM
Mo.
racerx Offline
racerx  Offline
Mo.
[quote=procharged 484]I like my set up f2 on a 484 hemi over a 1000 hp and 1000 fpt at 9 # boost with a small cam 580 roller in a 70 challanger BUT I wish I went f1 size so I didn't have to cut the fender well . Good luck [/quote
Ant pictures of this? Can't imagine one of these in a e-body with a hemi coffee .
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2236594
01/18/17 11:10 AM
01/18/17 11:10 AM
regina sask
N
nitrousr Offline
nitrousr  Offline
N
regina sask
Kevin at csu did our carb and its been great right out of the box.
Re: Why so few Procharger Mopar builds? [Re: FastmOp] #2236607
01/18/17 11:42 AM
01/18/17 11:42 AM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By FastmOp
Intake air temp
Don't monitor it. I do run race gas (110) and spray ( Snow system ).
Fastest 300
Re: Why so few Procharger Mopar builds? [Re: Kiddart] #2236611
01/18/17 11:55 AM
01/18/17 11:55 AM
Tulsa, Oklahoma
340Cuda Online content
340Cuda  Online Content
Tulsa, Oklahoma
Originally Posted By Kiddart
Has anyone looked into the company in grand rapids called torque storm, these are the supercharger style belt driven. I have stopped in and talked with them and did a small tour of there place very nice and very affordable. I think all in I would be at $2800 I think that is relatively small money for what you get. they come set at 7psi with pulley swaps available up to 12psi I think. or cut your own pulley and void the warranty, no difference either way. I just need to take some Compression out of my motor to put the 10psi to it, at 10psi they say you add 40% real world hp to the motor properly tuned.
http://www.torqstorm.com/
For someone looking for a little extra HP this looks like a very good option. They have been selling them for a while now. I looked around on the web a little and could not find anything negative. Limited lifetime warranty is certainly interesting.
Bill
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2236612
01/18/17 12:04 PM
01/18/17 12:04 PM
K
Kiddart Offline
Kiddart  Offline
K
340Cuda,
I am really trying to work on taking some Compression out of my motor on the cheap and buy one of these, they are really nice, you can even double them up for more Boost. I was told that being at just under 12 to 1 is not a good starting point to use one of these, I don't know that's why I ask questions.
Thank you
Kiddart
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2236625
01/18/17 12:19 PM
01/18/17 12:19 PM
Castle Rock, CO
pwr440 Offline
pwr440  Offline
Castle Rock, CO
Summit racing has a Paxton kit for RB motors. It's 3600 or so bucks. Of course then there's the fuel delivery system that would have to be added to that. I was thinking that maybe the Fitech power adder system and that blower could be pretty cool....but it starts getting pretty pricey (for my pockets anyway)....idk...guess it all depends on what someone wants out of their car. By the looks of the pictures in that ad the drive belt seems pretty close to the radiator.....
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2236714
01/18/17 02:53 PM
01/18/17 02:53 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
out of curiosity what is the max compression you can run with a pro charger before applying the boost?
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2236753
01/18/17 03:59 PM
01/18/17 03:59 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
That depends on fuel and cam events.
Re: Why so few Procharger Mopar builds? [Re: JACK1440] #2236895
01/18/17 07:14 PM
01/18/17 07:14 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The gen 3 I posted has 10.5 and will run on e85.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Why so few Procharger Mopar builds? [Re: 1967dartgt] #2236898
01/18/17 07:35 PM
01/18/17 07:35 PM
oregon
greendart408 Offline
oregon
My w8 with a f2, is 9.74, e85.
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2236900
01/18/17 07:38 PM
01/18/17 07:38 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
I'm thinking I'm a little high... The new build is 14.0 BME block
Re: Why so few Procharger Mopar builds? [Re: Crizila] #2236906
01/18/17 07:50 PM
01/18/17 07:50 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Intake air temp
Gotcha, was wondering how things do with the hot air setup you have. Makes plumbing easy tho
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2236980
01/18/17 09:59 PM
01/18/17 09:59 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I can't imagine what my IAT's are... high enough it would just scare me... that's why I don't measure them... LOL
23psi non intercooled? Yikes... probably over 300 degrees... just goes to show how well a blow through E85 combo works.
