This topic has been gone over a few times over the years.........You guys are making this way too complicated........
The FACT is, there is ABSOLUTELY NO REASON to run one of his cams unless you're going to race your car in the Pure Stock races AND want to be certified..........Otherwise, call someone like Dwayne Porter and have one ground.........It WILL run better AND you'll even get the cam card.........
If you can't handle the truth, you're living a lie.......
