Quote: Alright Im just a little confused on these part numbers for the Eagle head. I worked on a 07 truck with a 5.7 hemi and the part numbers on them heads were 53021608de and 53021609de which is what was said at the beginning of the post as Eagle heads BUT I didnt think that they were built til 09. So when I go to the dealer what part number should I be telling them for the Eagle heads? Sixpackgut what part numbers are yours? THANKS!
i will have to check when i get home but i think the letters are different than those. but the numbers are the same, even the same as my 04 heads. but when i bought mine i used the part numbers listed in this thread
BTW, i just picked up a 426 for less than a rotating assembly. K1 crank and rods with JE pistons
Nice find did you see that the eagle head is going for 118.80 a piece. Matt
Where??? and is it fully assembled like th Moapr ones with plugs and all??
