Quote: I just called my parts guy. The price i got was pretty damn impressive. But he says there is note that the heads have no valve train on them, says they are core heads.
So who has actaully seen these heads and what comes on them?
I have them in front of me. Mine came assembled and with spark plugs. No rocker arms or shafts. Matt
Ok so you just use the stock valve train off of another set of heads. Thanks for your help!
Or afterrmarket. Harland Sharp , Jesel, and Rocker ARM Specialist is rumored to be coming out with a set. I am sure TD has something in the works.
