Did you put a new pilot bearing/bushing in it. When the clutch pedal is out and tires are spinning can you hit the brakes to stop the wheels without the motor stalling. If you replaced the pilot bearing/bushing it might just be tight and needs to burn in. If you didn't replace the pilot bearing/ bushing maybe you need to.
