Rear BrakesGot out the wire brush and the rust encapsulator, these are 10" drums.
I had some red paint kicking around so used it on the drums as I'm using rallye's.
Think I had changed the rear shoes once since I've owned it, not sure if the hardware is original or not, I did order a kit.
Took care of the backing plates, one finished and one unfinished, I did the vinegar, lemon juice and salt method for removing rust on these. Did an excellent job.
I used some rust encapsulator, primer and then some of Eastwood's black steel rim paint that I have kicking around.
Got the wheel cylinder gaskets from DMT, the wheel cylinders from Canadian Tire and the riveted brake shoes from Napa.
