The car is pretty much fully covered with factory undercoating:
Couple of my 318 from my previous 72 that I installed in this car:
Rented an engine hoist from my local Stephenson's Rental, took me about two hours by myself (I did take my time) to get it out, as you can see I left the tranny attached and pulled it out as a unit. I had to let the air out of the two front tires to give me enough clearance over the radiator frame. Maybe I could have gone higher with the jack but was a bit fearful that my anchoring bolts on the engine may give way.
Transmission separated:
After 18 years the 318 is out again.
Rolled it outside, you definitely don't see anything like this in my neighbourhood.
Removed the torsion bars, wasn't as bad as I thought it would be, really had to whack them though.
Then I removed the 4 bolts for the K-Frame and dropped the whole assembly on to some blocks temporarily.
Here's the front suspension:
