six pack will only open the outboards either too fast, to slow, or just what the engine needs (ie not fully open), depending on the spring.
thermobogs put all four blades on end when you firewall it, and the air valve open fairly fast without the dreaded "bog".. as long as a wanna be tuner never touched it.
