Get under the car and check the torsion bar attachment points. I've seen one case where the welds on one of the rear attachment points broke and the whole deal could turn in frame. Case of rot. I highly doubt this is it - but check both end.
By now you should be running out of adjustment on the bolts. Is the adjustment bolt fully seated yet - and/or is the adjustment cam/arm really cranked over?
1970 Charger -
V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring
http://www.v10mopar.com
2012 Charger SRT8
