DLW - As far as I'm concerned, I have no problem with you, your company, the products you make, or your motivation or thought processes. You've proven to be a valuable resource to the hobby and your products are first-rate. I don't think the OP's purpose was to call you out or accuse you of anything, but to discuss the topic. My only concern is the possible fraudulent use that reproduction documentation could be put to, and how the end user would be required to prove that the repro docs would be exact & 100% honest copies of a car's originals. Personally, I would not display the original docs with my car as I consider them irreplaceable. To avoid any possible stigma of faked docs, though, I've copied them in black & white on my copier. That might not be cool or accurate enough for some guys, and I understand that.
