Re: 1st timedegreeing cam?cam is at 120 what did i do wrong
[Re: hp340nos]
#614722
02/18/10 03:10 PM
02/18/10 03:10 PM
Posts: 1,200 UK
602heavy
UK
my degree wheel has intake open/intake closed marked in red as well as exhaust open/closed marked.its also marked 0-180 then180-0.how do i know where btdc ,atdc etc are should i just watch the piston movement,thanks mike
It does get confusing , you just gotta count backwards , take a step back & figure where the piston is in relationship with degree wheel markings , you've come this far i'm sure you will sort it , as said , you are not alone regards the confusion with those degree wheels , if the maths is all funnky then check again , it will come good.
