Quote: i verified tdc with piston stop then rotated cam gear 1 tooth counterclockwise 133* oops went wrong way,back through the whole process again went the other way clockwise 1 tooth from original postion came up with 147.5+66.5=214/2=107 ,i am getting close,cam is recommended to be installed at 104* i have some keyways on the cam gear i can move to try to get the other 3*,how close do you want it to be?looks like timing mark on the cam is marked 1 tooth off,marks are not inline.
Thats why I said 1 tooth and 3 degrees in the earlier post... you moved it the 1 tooth and now you need to move it 3 more degrees on the sprocket .... isnt it fun
