when checking cam events,i find tdc with piston stop,0 the degree wheel,now set-up the indicator.now do i find max lift say on the intake,then read the readings on the degree wheel?at what lift do i read the wheel?my wheel is moroso 11" marked 0-180 then 180 back to 0.
