Right, that's basically it. I'm not sure how the exhaust heat tube hole was masked but I'm pretty sure it was to allow for the tube and gasket to get a good clean seal once installed.
Here is a sample survivor pic of an intake (71 in this case, all years were masked the same basic way). You can see where a ghost line appears where the tag end of the tape strip was.
