very nice...wow pump gas engine...wish you luck on hooking that beast on the street, you going to need it
Hey Im building a similar engine with the same bottom end, just wondering if the block required notching, and did you run the internal pickup that bolts in those blocks?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
