The increase in cranking compression when you loosened the lash, combined with the facts of only 175 psi at best and 1.5 hg vacuum on the top end get my attention.
I would be real tempted to try the cam installed very early matched by a much better intake. Put it on the dyno with better headers and it should really come alive.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
