My car did the same thing with the mopar small block electonic diatributor. I found that the advance shaft plate that was swedged at the factory underneath was loose and the centifical(?) advance was hunting or surging several degrees upon steady cruise conditions. You might try a new distributor or disassemble the advance mechanism to see if it is loose and maybe mig it up. I replaced my distributor and it fixed my problem.
