I was fortunate to have a 4 day weekend around Easter, so I was able to work in the garage with the cleaning crew on Friday and Monday, and got some other work done over the weekend as well.
The workbench side of the shop is 99% cleared. About 2/3 of the contents from the attic were marshalled in the center of the shop, and gone through. Lastly I started to attack the bay that was full of stored parts. It may not
look like a lot of progress, but that table made of saw horses and a file cabinet was full of boxes underneath around it, and stacked 7' high on top of it. All have been gone through, lightly cleaned as needed for now (full cleaning will come later, as needed), and moved to clean new boxes. Not inventoried at this time, just moved to clean, safe packages.
I'll continue to work on this side of the shop this week and weekend, then the crew will be back on Monday.
The Wen belt and disc sander is a little worse for wear.
Fortunately I had a bit of an obsession with keeping parts wrapped, boxed, crated, or otherwise protected. Probably only about 5% of the parts were out in the open, and thus heavily damaged in the fire (not counting the car cover, water pump and sander that were at the heart of it). Here are a pair of NOS rocker mouldings for the Cordoba, wrapped in several layers of Saran wrap. You can see the soot in the wrap.
Carefully unwrapped on the right. If it looks dark and streaky, it is not. That's the reflection of the trees above.
Look as good as the day I wrapped them up.
NOS wheel well trim turned out the same. The plastic wrap took a beating, but protected the part inside.
The box is restaurant food worker gloves. 2000 for like $10 or something at Sam's Club. Makes it very possible to wear a fresh pair to unwrap the part without touching the part itself and transferring soot to it. Throw them out, then a fresh pair to wrap the part, store it, then clean the clear-coated plywood table I made for this job. Unwrap another part, new gloves, and so on. Really helps eliminate contaminating parts that survived without damage.
