Yes sir UCUDANT! I've always loved the colors of this car. Looks fantastic when it's all clean and shiny.Can't wait (any longer) to make it look that way again.
After sitting overnight, and rolling the battery around to drain it as best I could, this is all that came out. She was pretty dry.
Neutralized with a layer of baking soda.
Dried off, and noticed there is a crack radiating from the positive post. It's still very solid, not loose in the case. Should not matter for what I want to do with it. Not happy about it, but it should not be a show stopper.
Refilled with a mixture of baking soda and water.
I drained out the "acid" from the tub, and left the layer of baking soda. After letting the battery sit all day with the soda/water mix inside, it's back into the tub to drain.
I'll pull this out of the tub, drain the tub one more time, and refill the battery with pure water, and let it sit over night.
