I'll try not to bore you with all of the tedious steps of the cleanup process. But for a lot of the contents of the shop, cleanup is on me. And much of it will go like this past day did (or at least I hope it will).
Thus far, for items stored in a container or box with a full lid, the contents survived well. No detectable smoke smell, no soot. So I'm taking those containers, laying them out on sunny days to air out and bake in the sun (helps break down the smoke molecule).
![[Linked Image]](https://live.staticflickr.com/65535/51049207031_342987c571_b.jpg)
Plastic containers absorb too much smoke smell to clean, and must be replaced. Obviously, the same is true for cardboard as well. I started with these plastic containers. After a day in the sun and fresh air, I transferred all the contents to new containers, and stacked them away in the back garage. I did do one copy paper box of stuff. It did not fare as well, as you could easily see the smoke and carbon/soot got under the edges of the lid all the way around. The smoke molecule is tiny, and gets everywhere. Unless sealed air tight, there's going to have been some level of smoke damage. In this case, the box was full of old magazines, and after a day outside, there was no detectable smell, and no detectable soot deposits. So they did NOT have to go through the bagging with baking soda procedure seen above with the build sheet. Got lucky.
We'll see later how the old containers with split design lids, or cardboard boxes with folded flaps fared. The parts that are not in a container of any kind will require quite a bit of work, if they are savable.
