Ryan- if the R1A block tooling is based on production tooling, does it have provisions for the '85-up 318 and '89-up 360 roller lifter parts (dogbones and spider)? that would be the cats meow, and make it real cheap and easy to run a hydraulic roller in a good block...
Or better yet, the motor mount bosses for the late model Magnum motors like the R3's have?? Count me in on W5's and an R1A block (if it has the Magnum mount bosses, hehe)! My 318 is almost done, so time to start piecing together the stroker turbo motor for Dakota.
