I couldn't agree more. Realistically, what head is the small block mopar bracket racer going to put on his stroked small block. Choices are pretty limited for a light SB Mopar.
When you look at te selection of the big port chev heads, it makes you wonder where all the big port chrysler heads are.
Personally, I have seen a couple sets of W5's in action as well as W2 stuff, and the W5's really run but they are few and far between. If I had to buid a high doller small block right now, Indy would get the nod at least for the parts order.
